Water Pressure while watering
Old 06-20-05, 11:13 AM
H
This is the first time I've owned a home with a well. I'm trying to water the lawn and I noticed that the water pressure drops when the pump turns off. When this happens, there doesn't appear to be enough pressure to turn the sprinkler head. I looked at the pressure switch settings and it cuts in at 34 psi and cuts out at 54 psi. I have a 44 gallon Flexcon Industries Challenger Series tank. The pump is coming on often. I'm afraid that I'm going to burn out the pump.
Old 06-20-05, 12:13 PM
Received 489 Upvotes on 402 Posts
Those pressures are normal. It seems your sprinkler requires more pressure to operate. You could try looking for a different sprinkler thta will operate with lower pressure.
Old 06-20-05, 12:18 PM
H
homerlp
Thanks joed. Should I be concerned with my pump going on every few minutes?
Old 06-20-05, 02:35 PM
P
If your pressure tank is the one I think it is, you have about 12 gallons of drawdown between pumping cycles. A large rotary sprinkler can use several gallons a minute. This will make your pump cycle frequently.
Ron
Old 06-20-05, 05:16 PM
Going on every few minutes is not a problem. Going on every few seconds is a problem.
