Shallow well pump - HELP !
Old 08-09-05, 09:32 AM
K
I just put in a new 1/2 hp shallow well pump. The pump kicks on & off & back on quickly before running. It seems as though the pressure is dropping steadly to about 30lbs then very quickly drops to 20lb & the pump kicks on. The pressure jumps back to 40 & the pump shuts off then quickly back to 20 & back on where it runs fine. Anyone have any ideas on why it would do this ?
Old 08-09-05, 02:15 PM
speedbump's Avatar
What kind of tank do you have?
bob...
Old 08-09-05, 06:09 PM
Received 489 Upvotes on 402 Posts
Your pressure tank is water logged. The type of tank you have will determine the solution. You may need to replace the tank.
Old 08-10-05, 06:23 AM
K
I have a WellSaver 20 Gallon Vertical Pressure Tank. I just installed that the same time I replaced the pump.
Old 08-10-05, 07:14 AM
speedbump's Avatar
Since I have never heard of a well saver tank. Is it a bladder tank or a galvanized pneumatic tank? Or does it have more than one plumbing fitting on it? And does it have a little schrader valve that you can add air to?
If it's a bladder tank, you may have the pressure in the tank set too high and sometimes the bladder will be stuck to the bottom of the tank. Although I think all the manufacturers have gotten past that problem.
bob...
Old 08-10-05, 07:42 AM
K
Sorry about that. It's a bladder tank. It only has one plumbing fitting. It does have a valve to add air. It came pre-pressurized. I belive at 38psi.
Old 08-10-05, 07:49 AM
speedbump's Avatar
Ok, that explains it. YOu have too much air in the tank for your switch setting. If you have a 20/40 switch, you need to turn off the pump, open a faucet until the water stops flowing. Let the air pressure in the tank down to 18 lbs. Turn the pump back on. Now it will function properly.
bob...
