lateral lines
Old 03-05-06, 04:49 AM
rj4374
Red face lateral lines
upgrading lateral lines need to be level whats the best way to level without a transit?
Old 03-05-06, 06:16 AM
majakdragon's Avatar
Drive a stake into the ground at each end of the runs and use a string with a string level. Adjust the string until level and then measure down to the laterals. Make sure your string is over the center of the pipe so you are measuring to the same height each time. Good luck.
