Pump buying help
Old 04-14-06, 11:25 AM
W
Pump buying help
Hi all, I have a pond and need a pump for it. The gph isn't yet know but I am looking for a pump that can handle large solids like it won't get clogged up by a leaf if it falls in and also is energy efficient. Any ideas on the kind of pump or what I should be looking at. Thank you.
Old 04-14-06, 04:32 PM
V
Vey
Vey is offline
You should filter out the solids before they get to the pump. If you don't want to do that, you might be looking for a "semi-trash" pump. They are more expensive and less efficient.
I found this website that has a lot of info on it.
http://www.certifiedaquascapecontrac...d-supplies.php
