Replacing pressure tank.
Old 09-19-06, 09:46 AM
C
Hi, I am replacing the existing 20 Gal. pressure tank because of a rust/rot issue. The new one is a fiberglass 30Gal. I have i/2 Hp a jet pump with switch, a gauge that reads around 30psi and a black rubber hose 1"o.d. that runs from the pump the pressure tank T . Can you tell me what I need in supplies starting from the jet pump, and do I need to do anything special to the new tank?
Thanks in advance, this site is super! Great job.
Paul
Old 09-19-06, 11:35 AM
Niadh's Avatar
You should be able to unscrew the tank tee from the old tank and put it on the new tank. If so you wouldn't need anything new except some teflon tape for the pipe threads. Depending on age or condition of the components you may want to replace a few of them. Here is a link to a modern tank tee setup with the components labeled so you can compare what you have to it (http://db.homelinux.org/share/incoming/tank-fittings.gif).
The black water line in-between the pump and tank is probably plastic. You use barbed connectors to hook them to the tee. Since you have an existing setup you should be able to reuse them. To disconnect the plastic pipe you may have to heat it.
The only thing you'll have to do to the tank is set the air pressure in it to match your pressure switch settings.
Old 09-20-06, 07:05 AM
C
Thanks, I'll let you know how it goes.
Paul
Old 09-20-06, 08:16 AM
Ed Imeduc's Avatar
Wink
If thats a air to water tank just turn it back on and thats it. If it is a bladder tank then you have to set the air psi in it 2lb less then cut in psi of the pump .Dont get that 30 psi? most switches are 20 lb psi 0n and 40 lb psi off.
ED
Old 09-24-06, 06:35 AM
C
Hi, The psi pressure for the tank is a reading empty or full ??
Paul
Old 09-24-06, 08:02 AM
Ed Imeduc's Avatar
Wink
The psi on the tank is when its full.. BUT BUT if the is a air to water tank 0 psi empty. When full and pump offshould read the 40psi but will be half full water and half full of air.
ED
Old 09-25-06, 08:09 AM
P
The precharge that Ed alluded to is set with the tank completely empty.
Ron
Old 09-26-06, 09:43 AM
C
Thanks guys.
Paul
