Cant get pressure from well
Received 0 Votes
Have a deep well (145' at 4.5gallons) with a 1/2hp goulds pump.
It is supplying a large pressure tank that feed 3 trailers.
Woke up this morning at about 6 to find no water.
Went out and checked the system.
No leaks at the trailers.
When I tried to start the pump it would get to about 10psi and no higher.
It also starts by sounding like nothing is happening then you hear gulps and after a few seconds get water. Mixed in with the sound of the rushing water is a popping sound that reminds me of air is in the line.
As soon as I let go of the lever (on the tank) the pressure drops to 0psi.
Disconnected the outlet line from the tank and attached a shut off valve. Started the pump and got the same sounds then water spraying from the valve. I closed the valve and still could not get above 10psi.
I opened the valve and let go the lever (the pump cuts off) and put my hand to it and got a sucking. The pump has a check valve on it.
PLEASE do not tell me there is a burst pipe underground.
It is the middle of winter and no one will be able to dig.
Is it possible that the pump is just air locked or something?
I am waiting for an adapter so I can pull the pump.
Thanks for ANY information,
Mike
Mike
Received 0 Votes
sounds like the pipe is burst in the well ( i think this would cause the severe sucking when pump is shut off noise he hears)...and i suspect if the pipe is burst in the ground...it would have found its way to ground level and be spotted
of course this is just a guess
