Septic Tank - Needs new baffle T?
Received 0 Votes
Had septic tank pumped today. Co. who did it says the "baffle T" is laying inside the tank; a new 1 has to be installed. 2 questions..what is a baffle T in a septic tank & how difficult is it to replace? As u guessed I am not a plumber!
Is the tank steel or cement???? Did they say they could fix it???? Did they mean the baffle that keep the stuff in the tank and lets the water out in the field ??? That would be like a T
Received 0 Votes
Yes it seems it is a sh%$#$% job! but unfortunately I wasn't home when it was cleaned. Don't know how big this lid actually is; will I need a backhoe to move it? Or can a couple of guys lift it. In My last house, the lid was pretty small where 2 guys could pick it up. I guess I'll have to dig up the lid here and check the size 1st. Also how the heck do these things "fall off" in the 1st place? If I do get the lid off, does this baffle T just slide right back on? Or does it entail any pipe fitting or soldering or junk like that? I have no idea even what this baffle t thing looks like!
You have to dig to find out what you have there. Should slip back in there. id get to it right awayIf you can . Hard stuff can start going into the drain field and the water is low if they just pumped it.
lauramar,
If you have to enter the tank or stick your head into it extreme caution must be used.
The environment inside of the tank might not just smell bad but could be toxic.
There is a high possibility of insufficent oxygen or toxic fumes.
Be carefull.
Be carefull.
Received 0 Votes
GregH is exactly right with his warning....a septic tank is considered a permit-required confined space in the industry and one should never enter a c/space unless trained to do so and a trained attendant should be stationed outside of the space maintaining constant communication with the entrant. You can be overcome by fumes/lack of oxygen before you even realize a problem is developing.
Received 0 Votes
Hi All
Not to worry.I never went in that tank. Instead I shopped around and found a reputable guy who is doing it tomorrow for $350.00. He said it would take about 1 hour. He also said I should report the crew that quoted me the $1700.00 price. Thank you all for the advice; glad I asked about this whole thing!
