zoeller pump - float stuck
Old 05-12-07, 05:54 AM
I
I have zoeller sump pump (M-53, I think) with a vertical float. The pump is working fine whenever it turns on. But what I have noticed is, when the water trickles down really really slowly in to the pit, the float raises all the way up but stays in that position and water keeps raising even above the normal usual pumping level. But if I give a tap on the pipe then I see the switch activated and motor starts pumping. This problem does not happen all the time.
Is the switch faulty? I found the switch in a local hardware store for some $28. I find it expensive because the pump it self they are selling for $125.
Old 05-12-07, 07:42 AM
P
Zoeller biulds a great pump, but their switches leave a little to be desired.
I would guess that the switch is bad, or getting there. They're not too hard to change, but make sure everything is sealed really well. You don't want water inside the switch.
Ron
Old 05-12-07, 07:50 AM
I
Hi Pumpman,
Can I replace the zoeller switch with a piggyback one? I saw in another post that some one did it. But I am not sure how they deactivated the one that is attached to the pump.
Any ideas?
