will my jaquzzi pump work for a shallow well?
Old 07-18-07, 03:03 AM
Y
its a 1 hp jet pump, any reason i cant set it up to a pressure tank and control box from 10 foot spring 24 feet down hill from cabin, not going to drink this water, just household use, thanx in advance
Gould Century 1081 is the pump
Old 07-18-07, 08:07 AM
P
I've never heard of a Gould Century pump, although I have heard both names associated with pump motors.
If it is indeed a true jet pump, it will work. However, if it's a spa type pump, I doubt that it will build alot of pressure, meaning it might be difficult controlling it with a pressure switch.
Please take another look at the pump and see if there is a name or model number on it (not on the motor).
I may be wrong, but I want to be sure of what we're dealing with.
Ron
Old 07-19-07, 03:54 PM
Y
RE:jaquzzi pump for well
ill check name and number on pump again, the guy who i got it from said he drew enough water from a stream to run 2 rainbird sprinklers at once, i dont know if there was any head to contend with tho, ill try and take some pictures too, thanx for helping, ill be back
