Pump doesn't shut off
Old 09-16-07, 07:41 PM
D
My well pump doesn't shut off. The pressure guage on the tank builds up to about 30 lbs but goes no higher even though the pump continues to run. The pump, tank, and pipes become very hot. I put on a new pressure switch but it made no difference. I drained the tank until there was only about 10 lbs of pressure and switched the pump on. It rose to 30 lbs and builds up no more pressure but continues to run. Could this happen because it is waterlogged?
Old 09-16-07, 08:18 PM
Received 442 Votes on 367 Posts
Could be a problem with the pump. What type of pump do you have. jet pump? submersible pump?
Old 09-17-07, 10:00 AM
D
It is a jet pump and is less than one year old.
Old 09-17-07, 12:37 PM
F
sounds like the tank is waterlogged...
Old 09-17-07, 03:24 PM
Sounds like the pump is unable to build the required pressure. I have seen this with jet pumps when a piece of debris is caught in the jet orifice. Could be a piece of rust or stick or pebble that was sucked up the pipe.
Pressure tank will not prevent the pump from building pressure. A large leak anywhere after the pump output would.
