pressure problem
Old 10-04-07, 09:02 PM
pressure problem
live on farm with a well, about 35 deep from foot value to pump. installed a new shallow jet pump about 3 months ago. worked fine till now. pressure will not climb to point of pressure switch shutting off pump - pressure mounts till 35 psi, pump continue to run. If i open a tap, can hear pump pushing through more water, pressure drops somewhat but not too low. I have both a galvanized tank and a bladder tank on system (galvaized tank is not water logged and bladder is holding its air). So a little puzzelled. any ideas before I start tearing the thing apart?
Old 10-04-07, 09:13 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Have you checked if you have water there at 35 ft ??
Old 10-05-07, 05:43 AM
Received 518 Upvotes on 423 Posts
I have seen this problem when the orifice in the jet gets a chunk of dirt in it. Could be a small pebble, stick or chunk of rust.
