Correct submersible voltage?
Old 03-18-08, 12:31 AM
A
My 2 hp, 3 wire submersible recently stopped producing water. I have a Franklin 2 HP deluxe controller. Well depth is about 500'. Pump seems to be running and doesn't trip. I did the resistance checks listed inside the control box, but I'm not positive I did them correctly. Anyway, the voltages I'm getting at both the control box and the j-box at the well head are as follows: red=280v, yellow=125v, black=125v. Do these voltages seem correct? Is it possible that replacing the control box might solve the problem or am I looking at having the pump pulled? I have no reason to suspect the water isn't there, no complaints from the neighboring properties. Also, the past couple of times I've pumped into my holding tank, I got the impression the gpm output was dropping, then this past weekend, nothing. So, it didn't quit all at once.
Thanks. Al
Old 03-18-08, 04:57 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Where are you located? The voltages don't follow US logic, and appear to be high. Where are you measuring the voltages from and to? (Ground, each other, etc.)
Old 03-18-08, 10:35 AM
nap's Avatar
nap
nap is offline
New Member
Received 1 Vote on 1 Post
have to ask chandler why you believe the voltage appear to high.
Nominal voltage in the US is 120 but the POCO is allowed +-10% which would allow 108 to 132 volts. I work in and area where the 480 volt (nominal) supply runs an even 500 volts all the time.
the 280 volt reading is from the start winding circuit and a cap will cause you to have a high reading. That is what it is designed to do.
ark, do you have access to a clamp on ammeter? and are you very comfortable with electricity?
Old 03-19-08, 01:02 AM
A
Thanks for responding...I'm located in Young, AZ. I'm measuring voltage to ground from each of the three wires individually. I'm pretty comfortable with electricity, but need to get a clamp-on meter. I'll get one before I head back up.(the well in question is on a piece of property that we use on the weekends). Also, the whole set-up is only about 2 years old. So, what tests would you suggest I run next?
Thanks
