Well pump - Electrical
I'm trying to wrap my wee little mind around the wiring for a 220 Volt two-wire pump. I'm being told it needs two wire w/ground and I can follow orders, but it goes against my marginal experience. I have always wired 220-240 volt anything with three wires w/ground. Red and black both hot, white neutral, and the green ground. Can you tell me why this is different and the neutral isn't required?
If this is best suited for electrical forum, let me know and I will re-post there.
Thanks
Thanks
Neutral is only required if 120 volts is needed. A pump does not need 120 volts so no neutral is required. A dryer or stove has 120 volts components like lights , timers, conveinience receptacles that require the neutral.
