shallow well pump loses prime
i have a mcdonald jet pump 8110,hooked to two shallow wells about 10 inches apart .the pump loses prime after about a week. have redone the sunction lines . i have pressure check sunction lines ,no leak. have had pump reworked and still have problem have a bladder tank hooked to it.bladder is ok. the sprinkler system uses about 12 gallons per minute per zone with 7 zones, on a timer with separate control valves. once i prime again ,works for a week or more .could the problem be that the wells are too close. system is 6 years old and worked fine till a year ago. the house is in florida
