Well pump does not stop/pump
Old 06-01-08, 05:24 AM
P
Goulds pump was pumping tons of water a week ago, but when shut off, would start/stop every 3 or so minutes, so figured it needed a new air pressure tank, Got a new one, checked pressure before installing, and it was 28psi. Cut in at pressure switch is 30, cut out is 50.
For the sake of it, I primed the pump by pouring water down the steel pipe on top which holds the air tank, then started the pump, and it just hums. Does not stop, so I shut it off. Man, before the new air tank, I was getting a deluge of water, so well is not dry. Any ideas, people?
Thanks,
Joe
Old 06-01-08, 06:39 AM
V
Vey
Vey is offline
Not enough info.
What size tank did you buy?
When you say the pump "just hums" are you saying that it doesn't run?
Old 06-01-08, 07:08 AM
Received 251 Votes on 221 Posts
Neeed more water to prime it. The intake pipe needs to be full. The pump can't pump air.
Old 06-02-08, 08:05 PM
need to pour water in the top of that pump until the water fills to the top and stays there. if it never fills to the top with water you might have a check valve hanging open somewhere in that suction pipe. by humming i hope you dont mean that the motor shaft is not spinning and motor has just a low hum..
Old 06-07-08, 05:27 PM
R
jet pump won't build pressure
i lost water in house. went out to pump house and pump
was running and pressure guage was 0. replaced foot
valve and switch, but the pump wont build pressure over
30 psi to cut pump off. i even had the ball valve off to
house still would not build pressure. please help
Old 06-07-08, 06:09 PM
V
Vey
Vey is offline
Come Monday you probably need to call a pro to come and look at it. No shame in that.
Old 06-07-08, 11:59 PM
did you make sure everything to the suction was good and tight? might just be a stopped up jet in the head of the pump not letting it build pressure.
