water pump leak
Received 0 Votes
water pump leak
recently my water pump began leaking somewhere between the motor and the pump can this be repaired or do i need to buy a new one
If it is leaking and still building pressure. You should be able to get it repaired. It sounds like a seal or a gasket has sprung a leak.
Any good pump guy, or pump supply house should be able to repair it.
Travis
Travis
