Water gushing into Sump Pump for 3 days after rain, pump working non stop.
Received 0 Votes
Does the pump ever shut off momentarily?
Where are you pumping the water to? Is it well away from the house?
Can you see how much is actually being dischaged?
It sounds like your drain tile system is collecting the water properly, but here is more water in the soil than normal.
Dick
Dick
Received 0 Votes
It sounds like your sump pump is just recycling rather than pumping out the water.
That means... the water it manages to pump out is coming back into the pit somehow.
That can happens for a number of reasons. You should check each possibility. Here are some of them:
- Faulty check valve. It is not keeping the pumped water out.
- Frozen discharge line. If it is too cold where you live, the discharge line might be clogged with ice.
- Discharge lines that pouring the water too close to the foundation walls. In that case you should extend your downspouts a few feet away from the foundation.
If none of these work, have a waterproofing contractors inspect the pump and the place.
Received 0 Votes
To deal with the immediate situation: If there is enough room in the sump, you can buy another pump at Home Depot / Lowes. Discharge it through a big (3/4") garden hose to a point far from your house. Power it from a circuit different from the one powering the existing pump so you don't accidentally trip the breaker.
