Pump for house will not turn on
Old 03-02-09, 02:02 AM
L
Our water pump to our house will not turn on unless I use a wooden stick or clothespin. I have to do this about every half hour. How do I fix that?
lilacpoint.
Old 03-02-09, 04:04 AM
D
Received 1 Upvote on 1 Post
What exactly do you do with said stick or clothespin ?
P
Are you manualy pushing the contacts on the pressure switch with the stick? I'm not a well guy but if the pump builds pressure when you do that it sounds like maybe you just have a bad pressure switch (about $20 part). The well guys should be able to help you further.
