Shallow well pumps water then air then water..
Old 05-10-09, 07:20 AM
sdanville's Avatar
I have a shallow well for my cabin. I only need 40 PSI and set it there.
For years I have had this problem of the pump running too much. Last year I had a well man replace the pump and inspect. He said the pump needed a new impeller. That did not fix my problem. When testing directly from the pump , the pump will push water, then pause then push water than nothing... when all hooked up...often I can watch the guage jump from 10 to 40 psi back to 10 etc and sometimes it will make it shut off and on every second for a minute or two, So its going CLICK CLICK CLICK etc on and off...I would guess a air leak between the pump and well , but have everything wrapped with plastic wrap. Our water table should be up. The well man put on a new point last year. I have googled this and doesnt seem like bad pressure tanks, check valves or leaks is my problem. Any Ideas why my water pump draws water consistantly inconsistant ? I am starting to think my well point is only partly in the water.
Old 05-13-09, 08:14 AM
P
This is a head scratcher, so let's just start somewhere.
You haven't said what type of tank you have (or pump), but if it's a bladder type, then follow the instructions on the above sticky to makle sure it's not waterlogged and has the right amount of air in it. If it's a galvanized steel tank, the instructions are there to cover that also. This will at least eliminate this as a problem.
What pump are you using? Has the foot/check valve been replaced?
It does sound like the pump may be starving for water (too much pump for well?).
Info on pump and tank sizing may be helpful.
Ron
Old 05-13-09, 09:46 AM
sdanville's Avatar
reply
1) My problem happens before the pressure tank.
I can disconnect the line from the pump to the tank and it pushes water than not then water then not.
The pump is like a 3/4hp Ace hardware pump.
it is not the bladder type. Its old and works fine.
I know nothing about check valves. I do not lose pressure once its up.
My problem is inconsistant sucking up of water.
I think I have to drive the well point down a foot and see what happens.
the pipe is only the 2 inch.
its about 12 feet deep.
Old 05-14-09, 07:48 AM
P
Then I would have to say that the pump is starving for water. You might be able to help it out a little by partially closing the discharge valve (if one is installed) so that the pump can't pump down the level as fast.
It does, though, sound like a long term solution will be necessary.
Ron
Old 05-14-09, 09:19 AM
sdanville's Avatar
discharge valve
thank you very much.
I will google discharge valve as I dont know what that is,
other than it must be an option to slow down the water flow.
Steve
Old 05-15-09, 07:57 AM
P
The valve is a regular ball valve. It's just installed on the discharge side of the pump.
Ron
Old 05-15-09, 08:35 AM
sdanville's Avatar
discharge valve
Ive got one. Will try working it tomorrow and report back.
Old 05-19-09, 06:52 AM
sdanville's Avatar
Better pumping...
For whatever reason, my pump was much better this past weekend. Not perfect, it still gulped for air but not so much.
Talking to a local, a few days before there were major storms so maybe the water table went up an inch. I will report back as the summer goes by. Follow up is what many forum problems are missing. Often I wonder....so what happened ? Was it ever fixed ?
