Jet pump and tank replacement ?
Old 07-15-09, 05:27 PM
MICKY B's Avatar
I AM REPLACING A GOULD 1/2 HP JET PUMP,AND PRESSURE TANK THIS WEEKEND.THE OLD TANK I BELIEVE IS ABOUT 20YRS OLD.I AM REPLACING WITH SAME PUMP AND NEW BLADDER TANK.WILL I HAVE TO PRESSURIZE THE NEW TANK ? AND BEFORE STARTING PUMP WILL I HAVE TO PRIME THE NEW PUMP ?HOW ? HELP !THANKS ,MIKE
Old 07-16-09, 10:17 AM
V
Vey
Vey is offline
Put in a new pressure switch, too.
The pump will come with instructions. You will have to prime. To prime, fill up the pump body and (this is where people mess up) the pipe back to the check valve. Then start the pump. Wrap your hand around the body and when it starts to warm up (after about 30 seconds or so) if no go, then do it again.
But this should be fully explained in the pump manual.
Likewise, the tank will come with instructions.
Read and follow the instructions before you even start.
