Solar Power Sump
Old 11-25-09, 06:53 PM
Solar Power Sump
Is there such a thing that a solar powered supply could run a sump pump? You would never need to worry about the power going out again. I have a battery back up but its not very strong
Old 11-25-09, 08:11 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Doesn't the sump pump usually run when it's raining and no sun?
Old 11-25-09, 08:25 PM
GregH's Avatar
Super Moderator
Received 38 Votes on 36 Posts
Solar cells themselves can not run anything as power hungry as a pump.
They are used to charge a battery over time and then run down the battery in a short amount of time with a high current load.
What do you mean by strong?
Old 12-01-09, 09:58 AM
I'd guess his battery is weak and the pump isn't running long anymore. More than likely the battery just needs replaced. Or maybe he's using a regular car battery instead of a deep cycle marine battery. There is a HUGE difference in performance between these two batteries.
As for solar powered pumps, there are companies that make them. I know Grundfos makes the SQflex line which is a solar powered submersible pump that can be used for a whole house water supply.
I don't think anyone has a sump pump that runs on solar power. Like was said, you would still need a bunch of batteries to store the power because usually when it rains the sun isn't out. I can guarantee you can buy a generator to run your sump pump for a heck of a lot less than what a solar powered unit would cost.
Cheaper yet, try a new battery. I'd bet that's the issue.
