Well Pump Pressure switch defective?
I just installed an 80 gallon pressure tank, tee and all the necessary items along with it including a BII Pressure Switch. I've tried adjusting it according to the label inside the cover but it appears the lowest pressure, and largest range, I can set this 30/50 switch is 40 PSI (cut-in) with the cut-out at 50 PSI. The approximate differential on the box is 15-30 PSI but I'm only getting 10. I'm wondering if there is a trick to adjusting these or if I have a bad switch. Currently my pressure tank's pre charge is 28 psi and I would like to keep it there by having the pressure switch cut-in pressure at 30 but I can't seem to do it and now I'm worried I'm destroying this brand new pressure tank... not to mention the additional cycling of the pump.
These things usually don't need much adjustment. Maybe a tiny bit to change the 30/50 to 28/50, but that's about it.
You should read the sticky here. http://forum.doityourself.com/wells-...well-info.html
and maybe you will get a clue as to what is going on.
I don't know if I explained this correctly; I have an old Square D pressure switch that is probably as old as the old pressure tank I replaced. The Square D is dead on when I installed it on the new system working at 30/50. The new switch is a BII, that is supposed to be 30/50, but apears to operate, at best, at 40/50 when plugged into the new system. I want to know if I can adjust this new BII switch and how. I've don't want to continue using the 20+ year old Square D switch which is why I bought the BII with the new pressure tank. I'm thinking I have to chalk the BII switch up to a loss and invest in a new Square D, but I thought I would check here first.
You shouldn't have to fiddle with a switch to make it work.
If you don't have one, get a new gauge, too.
