Submersible pump in surface well?
Old 05-12-10, 12:34 PM
Hi,
I need to replace my jet pump and I am thinking about replacing it by a submersible pump. My surface well always shows seven to eight feet of water and I would suspend the submersible pump approximately three feet over the bottom of the well. Is there any counter-indication about using a submersible pump in a surface well?
Thanks in advance,
JF
Old 05-12-10, 07:03 PM
V
Vey
Vey is offline
None that I know of.
May want to size the pump a 1/4 - 1/2 horse lower than the surface pump. Submersibles are more efficient and more productive and we don't want to run the well dry.
Old 05-13-10, 08:19 AM
P
Received 2,180 Upvotes on 1,950 Posts
I try to replace surface pumps with submersible whenever possible in my rental houses. They don't need priming if the well is run dry.
