Please help again! Water pump issues, again!
Seems like you just changed the checkvalve. The foot valve is down the well at the botton of the line. Its that or you have a suction leak somewhere in the pipe from the pump to the footvalve.
Read this on footvalves:
Foot Valves used on piping for Water Wells, Explanation & Repair Advice
Mike NJ
Mike NJ
Thanks Mike! I read the article and I believe you are right! I saw the valve he changed and it looked like a check valve to me! Maybe I mistook what he said? I had my "handyman" guy actually change it. I think he called it a foot valve. Maybe he doesn't know much! lol IDk! Anyway, if I am understanding everything correctly ALL shallow above ground water pumps have a foot valve in the well? I imagine this would be a real pain to change? I'm not even sure where my well is located on the property. I lived there for 30 years and we never knew where the well was located. Maybe I should call a "real" plumber! ? lol Thanks again! Jack
Well the problem is they are going to try to sell you a new well. You have $10,000 lying around go for it.
When was the house built??? Mine is 1950 and there were no pitless adapters then. If your house is newer it should be simple. You just need some muscle to pull the line up. That is if its indeed the issue.
I would call a well guy to give a est... Make sure you tell him you only want the ft valve changed, but let him tell you whats wrong.
Be careful. Alot of scammers out there. They got my neighbor for $12,000 and went 133 ft. After they pulled the old line out I went over there and the ft valve was shot. I showed the owner, and he said they told him the well was dry...LOL
Good luck and let us know the outcome.
Mike NJ
Mike NJ
Thanks Mike, we never had our well go dry in the 35 years my parents lived there. The house was built in like 1923 or something like that, so it's really old. Guess I'll have to do some calling around and see what I can find out. Jack
What type of pipe leaves the pump? You may have a driven point also. Sometimes the points clogg. The old trick was to shoot a .22 cal down the well. I dont recommend it though, sometimes the bullet would come back up at you...LOL
The town may have some reconds, but local well drillers that replaced wells in your area will know whats down there. Find a trusting company.
Mike NJ
Mike NJ
Hello again! And thanks all! Pump keeps losing prime. Finally called a local plumber/pump repairman!!! When I talked to him on the phone he asked me if my well was dug or drilled. I'm guessing dug as old as the house is and being that nothing was ever done as long as we lived there, but who knows. He said something like old dug wells sometimes or usually don't have a footvalve on them. Anyway, thought I'd update everyone and hopefully get it figured out today! Plumber is coming! Thanks again! Jack
Plumber came down and checked it out. Found that the pump had a little itty bitty leak around a bolt and thought maybe that was the cause. He tightened up the somewhat loose bolts on the pump. He then confined all the water and pressure to the tank and pump. He then turned on the water and since it was slow to build pressure, he now figures that the well will need to be dug up and that he's pretty sure it's the foot valve in the well. If that doesn't make sense I'm sure i misunderstood what he may have said. He seemed to know more than anyone else I've spoke to, in person anyway. He had spoke with his dad, who has worked on these pumps in our little town for 30+ years and his dad said he thought they were mostly drilled wells. His dad even had a general idea where the well might be located. So, I guess sometime soon it looks like I got some digging to do! Of course I will keep everyone updated! Thanks as always! Jack
Thanks Mike! I already own a metal detector, just not sure how good of one it is. I'll give it a try or find a better one. Plumber said it looks to be about 3 feet down.
Oh yeah, he even made 2 trips to the house and had almost 4 hours of labor! He said he felt bad charging people for just messin' around. He said he only liked to charge his hourly rate if he was bustin' his ass! lol Great guy!
