help... no water for mother-in-law
deep well .... no water coming out... have replaced with new pipe... made sure it was not clogged and not pulling up sand. is there such a thing as the water table in the dry season, dropping too low for the pump to draw?
Yes, wells can go dry. Heavy pumping by others in your area can dramatically affect the ground water level.
Is the pressure switch sending power to the pump? Is the pump actually working? What type of pump set-up do you have? Is there a venturi, check or foot valve in the system?
If this is a jet pump, You have to be sure to get all the air out when you are priming it.
If this is a submersible pump. Are you sure the pump is deep enough under the water?
In addition to insuring that all the air is out of the lines when priming, if you have a jet & venturi down in the well a small bit of dirt or rust caught in the venturi can dramatically reduce the flow or totally stop the flow of water out of the well.
