drywell top
drywell top
I found the top of my drywell rotted and the soil that was on top fell in...i was wondering what to replace with after i clean the rest of the old cover off..
It will depend on the size of the opening and how permanent you want it to be. Also if you want to be able to access it at a later date. Some options would be treated wood frame and treated plywood, concrete poured over a wooden top, or maybe you can get a pre-made top from a septic service. Really depends on how you wanna do it.
If you want a concrete top you do yourself then you have 2 choices...form and pour a slab at least 2 inch thick (for foot traffic only..no cars or 4 wheelers) and move it over the hole after it sets up. Or option 2 is build a cover that can support the weight of the concrete and pour in place. If you want a lid you can open later you have to make those allowances in the concrete pouring. If it is where it will be or could be ran over by vehicles I would make it at least 3 inch if not 4 inch thick. Rebar in the concrete would be optional.
