Galv tank - Air Volume Control valve split?
Got home to find that my deep well jet pump was running. Opened the basement door to find a river of water flowing from my tank to my sump. Turns out that the air volume control vavle split (?). There was a line of pinhole leaks running up the side. This thing doesn't look like its going to be easy to remove and replace. Is it replacable? Are they standard? Do I just go to HD and ask for a AVC?
Fun way to spend my Saturday during holiday season!
They are easy to replace. It should just unscrew out of the side of the tank. Remove the line that runs up to it, it should be put on with a compression type fitting. Any well supply house should have it, or a suitable replacement for it.
I personally have never had any luck with air volume controls.
I just replaced mine with a bladder tank but removed the air volume set up years ago and installed a shrader valve instead.
Most of those galv tanks had a floating Styrofoam disk to reduce air absorbtion.
I only needed to "air up" the tank a couple of times a year.
Really though, this would be an excellent time to update to a bladder tank.
So, it turns out it's a Jacuzzi Brothers AVC. The guy I spoke with said they were popular in the 60s, and that if I could find one it'd be pretty expensive and that I'd br better off putting that towards a tank with a bladder. So until I figure out what I'm going to do I put a schrader in the side of the tank, and plugged the connection on the pump.
