Source for 1 1/2" Discharge Hose
Does anyone have a source for decent quality 1 1/2" discharge hose. It is for a sump pump and will be hooked up to an adaptor/nipple where the 1 1/2 PVC leaves the house.
I want the round corrugated type. I found some on amazon manufactured by Wayne, but some of the reviews said it had pinholes in it when they received it.
Thanks.
Thanks.
For aesthetic reasons it needs to be able to be removed from the house and stored.
Your going to disconnect and store a discharge for a sump pump? Wouldn't you want to keep it connected in case the basket gets water in it?
If you really want a flexible hose I suggest checking out the stuff they use to plumb spas/hot tubs. I know a company that uses this all the time for the discharge on basement water proofing jobs. It is a thicker wall, smooth reenforced hose. Looks like this:
http://ep.yimg.com/ca/I/nationaldisc...2188_119100383
Google "1 1/2" white spa hose"
Home Depot Sells it
Just did this job over the weekend and after searching all the specialty plumbing supply houses, I happened upon 100' coils of 1 1/2" discharge hose at Home Depot for $62 per roll. Fantastic, but really difficult to work with in cold weather. Let the sun warm it up or bring it inside for a bit if you're in a cold climate.
Thoughts?
