wellmate pressure tank is spurting water out of the vent line
Old 03-10-12, 04:52 PM
Hello,
A few days ago we replaced out pressure switch. Since then I have noticed that the vent line on top of the pressure tank, which to me best knowledge is a wellmate hp quick connect series, is spurting out water. What would be causing this?
Old 03-10-12, 05:12 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Think you need a new air volume control.
http://www.wellmate.com/en-US/support/
ike NJ
Old 03-11-12, 08:46 AM
Since the air volume control in located inside the pressure tank is there anyway I can check that this is really the problem from the outside? Are there any indications that the avc is not working be checking the pressure in the tank or the cut in and out pressures for the pump? Taking the avc out of the tank seems like a big job.
