Pump has no presure or water coming out
I have no presure or water coming out of pump. I have a brand new 1hp deep well pump, new foot valve, new ejector and a three year old 20gal bladder tank. The well is 75 foot deep with 6ft of water from the bottom. The pipes and the pump are full of water but there no water coming out of the pump. The pump sounds like it is trying to pull the water up but nothing comes out. Pulled the new foot valve to check and it was clean. Tried almost everything need some good advice and water.
When you prime it, make sure that you fill the pump and all the pipe to the foot valve. That's a lot of water. Then after you are sure the pump and pipe are full of water, turn it on.
