terrible septic smell in bathroom!?
Received 0 Votes
I had my septic pumped in november of last year. I got it most buried again, but not all. I'm a single woman who has my own home if that puts it into perspective lol
The bathroom in this house was built partially over top of the septic (something I will atttribute to the previous owner).
In the past, the entire house has smelt like septic before when there have been excess amounts of water (melting snow, heavy rain) and the water would pool around the septic. As soon as I would drain the water there were no issues.
Now, however, for the past 2 -3 weeks there has been a terrible smell coming from the bathroom. I removed the side cover of the tub, to see because initially it smelt like rotting cabbage or broccoli. It is just getting worse and worse, the smell does not come and go. When I go outside and stand at the septic bed and at the side of the house, I can smell this obnoxious odour too.
Any thought/ideas on what this could be?
Thanks for your help in advance
Received 0 Votes
Is there a drain that you are not using? I have a shower stall in my house that never gets used. Every few weeks or so, I have to put a couple of quarts of water in the drain to maintain the water level in the trap. If I let it dry out, then sewer gasses come up and the results are exactly as you describe.
It doesn't have to be a shower. It can be any drain that doesn't get regularly used.
Received 0 Votes
Problem solved....the lid of the septic was left open! Like I said the bathroom was built over it so I couldn't see that it was open until I started pushing dirt / sand in there to try to cover it up more....the entire lid is gone. The person who pumped it probably left with it
Thanks for your help, Vey!
