well with 2 pumps
Old 05-25-13, 08:19 PM
D
well with 2 pumps
I have a standard well 100 ft about 6 inch casing. It has a Franklin 240v submers. and works
good. I have wanted to go solar and install a DC pump alongside the existing pump and water
pipe. Would there be enough room for 2 pumps and water lines??? Has anyone seen this before??
Old 05-25-13, 08:26 PM
Received 3,410 Upvotes on 3,059 Posts
With the model number of the pump you would know its diameter.
I doubt you could fit two pumps in one casing.
Old 05-25-13, 10:22 PM
sure its possible to fit 2 subs in one 6" well at different depths... but depends on drop pipe size, 2nd submersible diameter, etc. if money is not a problem, take a look at the grundfos sq flex pumps...
i say get a backup generator and leave what you have alone.. jmo
texas wellman is the one to ask. i'll see if i can get him to chime in.
Old 05-27-13, 07:57 AM
T
Install a Grundfos SQ Flex pump. It will run off any voltage 114-230V AC or 30-300V DC. It needs at least 90V DC to run which will take about 3 200 Watt panels in series. When running solar flow into an open container. The more pressure you need the more power (panels) you need. Store water, not electricity.
Old 05-30-13, 07:53 PM
D
the little Sun pump I was looking at used only 25 watts DC and would trickle feed a cistern
all day from 100 ft down. for 600$.
Old 05-30-13, 08:55 PM
With only a 25 watt pump ..... that's about what you would get...... a trickle.
