When to replace a sump pump
Hi, This is more of a "what would you do" or opinion-type question. Is there an age at which you would definitely replace your sump pump? I'm thinking about replacing mine for peace of mind more than anything. It was the existing pump when I bought the house six years ago so I don't have any idea how old it is (house is 36 years). In any case, at least seven years old. I uncovered the pit just now and see that it is a Zoeller pump. It looks to be a M53 when I compare it pictures I see online. My house has no gutters and a weeping tile system (in addition to being in a fairly wet area) so this pump gets a workout in the summer months. In the winter we're frozen solid (NH) so I never hear it. It's an unfinished basement but there's plenty of storage and I want it dry. What do you think? Thanks for your thoughts!
Why not just make the needed corrections outside so the pump may not even be needed?
I'd just buy another pumb and have it ready to install and keep the old one.
Has it ever failed, is it making a noise?
Thanks for your response. I'm not sure what you mean by "needed corrections outside". Do you mean install gutters? If so, I'd rather not because of the maintenance and ice/snow problems that would entail. I think the current weeping tile system works great but I just wonder what the life expectancy of this sump pump is. I thought maybe there would be a consensus that it's a good idea to replace it after x-amount of years. Since I know it's 7 years old (and it may be 10+ years old) I thought it would be a good idea to get out in front of a potential problem. And to answer your last question: no, the pump seems the same as the day I moved in. Never failed, never made anything but the usual noises.
That is a good pump and made to last. I would keep a replacement on hand.
I would also recommend a battery operated water detector alarm.
Basement Watchdog Battery Operated Water Alarm - Home Depot
That sounds reasonable. I picked up an alarm this morning. I'll order up another M53 but leave the old one alone. Looks like Amazon has them for $123. Thanks for your advice.
One more suggestion -
Pre-fit the replacement pump on a dry day.
I highly suggest pre-assembling the new pump with matching pipe.
Cut the pipe so the backup pump's pipe is a standard height, say 3' with the pump on the floor.
(standardized sump pumps is something I learned from dealing with rental properties)
Remove the existing pump and pipe, set on the floor and cut at 3'.
Reassemble the piping, and connect with a rubber pipe coupling.
Voila- standardized, swappable sump pump setup.
Originally Posted by beachhead2
That's a good suggestion, Hal. Anything to minimize screwing around when the water is backing up. Thanks!
Hmm, someday I'll have to lobby to add that to the plumbing code-
"all sump pumps shall be installed in a manner that they can be replaced in under one minute
using a single standard blade screwdriver"...
