submersible pump: misbehaving pressure switch and pressure gauge
Old 06-17-13, 06:57 PM
G
I have a submersible pump in a domestic well and use a Square-D 40-60 pressure switch.
I drained the tank and then installed a new switch and gauge but could not get the switch to cut in at 40psi and cut off at 60psi. It was more like 49/60. The water system turns on much more frequently than in the past and runs for a shorter time. I'm afraid of blowing out the pump with too many cut ins.
I replaced the switch and gauge with new ones again, and got roughly the same readings. I fiddled around with it and could not get the cut-in below 49psi.
So, I've installed 2 new pressure switches and 2 gauges and have a problem.
I'd read somewhere that I could lower the cut-in to about 30psi while having the cut-off still be 60psi. I can't get the system to 40/60, much less 30/60.
Any help in at least making a proper 40/60 setting would be fine. Setting it to 30/40 would be really fine.
Looking forward to receiving a response.
Old 06-17-13, 07:03 PM
Received 3,419 Upvotes on 3,065 Posts
There are several videos on you tube.
The link i left is a pretty good one......easy to follow.
Let us know how you make out.
Well Pressure Switches - YouTube
Old 06-17-13, 07:22 PM
Received 1 Upvote on 1 Post
Far more likly there's a problum with your air pressure not the switch.
Old 06-18-13, 05:14 AM
V
Vey
Vey is offline
So how did you adjust the tank pressure? We have a sticky here that explains how to set up a tank properly, both the new style tanks that have diaphragms and the style that don't.
http://www.doityourself.com/forum/we...well-info.html
Old 06-18-13, 08:12 AM
P
Received 1,764 Upvotes on 1,577 Posts
What pressure range switch did you buy? They come in different ranges. 40/60 psi is the highest I've seen commonly available on store shelves though they do make higher pressure range ones.
Old 06-18-13, 08:31 AM
Z
Received 93 Upvotes on 85 Posts
hi gscot-
...I drained the tank and then installed a new switch and gauge...
Why did you install new stuff ?Were you having a problem?
