Need help in selecting pump set for agricultural purposes.
Which is the suitable submersible pump for lifting water from 600 feet for 6 inches borewell with low voltage ?
How many stages and power(HP) should be opted ?
Thank you.
Thank you.
Received 38 Upvotes
You forgot two important parameters, what pressure do you desire and what flow rate?
BTW, you cannot "lift" water 600 feet, you pump it that high. 600 feet from the pump to the surface will require in excess of 300 psi at the pump discharge.
