Shallow well pump won't build pressure
Old 07-31-13, 08:01 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
I replaced the 4.5 gallon bladder tank with a 20 gallon & adjusted the tank pressure to 28# (30-50 Pressure switch). Now the pump won't build pressure. Flow directly out of the pump is about 5 gpm. I'm suspecting an air leak but don't know why since nothing on the suction side was touched. Pump is a 1/2HP Goulds model J5SH. Well is aprox. 30 ft. deep & pump is only pulling 10-12" vacuum.
Old 07-31-13, 08:16 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Hi grady... Why the tank replacment???
What does it do...run and run???? what is the final pressures....?
If not suction leak I find faulty foot valves and priming issues to be culprit to be related...
Is 5gpm normal????
Old 08-01-13, 03:57 AM
Grady's Avatar
Constantly runs but won't get to over 15# pressure.
Old tank had a bad bladder.
Yes, 5 gpm, more or less, is normal. If I disconnect the house supply & discharge directly off the pump into a bucket, there is good flow.
Old 08-01-13, 06:54 AM
lawrosa's Avatar
Super Moderator
IDK... Open the nozzle clean out plug on the front and see if the nozzle is clogged... That can cause your issue...
I know thats a noryl impeller... Could you have melted it from it running??
Old 08-01-13, 06:04 PM
Grady's Avatar
It was the nozzle. A 9/16" wrench, little red screwdriver, & a piece of stiff wire were all that was needed to get it up & running. Once I dug & poked out the crud, I started the pump & allowed water to come out the nozzle plug hole for a few seconds before reinstalling the plug. Run time is 2:10 with no flow.
Thanks for the help. I owe you one.
Old 08-01-13, 06:36 PM
lawrosa's Avatar
Super Moderator
Cool.... What kind of crude??/ You have galv pipe????
Old 08-01-13, 07:47 PM
Grady's Avatar
There are two 1.25 x close nipples, one 1.25 x 4 nipple, & two 1.25" unions on the suction side which are galvanized. All the galv on the discharge side is now gone & replaced with brass. Suction line is poly. Well pipe??? Water is typical Kent County, Delaware shallow well water; Low pH, some iron, & probably moderately high nitrates. Not mine & the owner doesn't want to do anything about it so...
