Septic does not pump automatically with timer
Old 09-03-13, 06:21 PM
T
My septic does not pump automatically according to the timer. The alarm will go off outside on the control panel, then later go off inside the house. I can open the panel and run the pump manually just fine. I checked the timer and it has not ran for a day now. Is there a quick way to test the timer to see if that is what needs to be replaced?
Old 09-03-13, 07:55 PM
Received 3,420 Upvotes on 3,066 Posts
Welcome to the forums.
Most systems like that are controlled by floats.
Is your system supposed to pump out based on time or does the timer just log the pump running hours. If no one stops by with knowledge of your system...... I'll need a few pictures or control make and model......otherwise I'm just guessing.
Old 09-04-13, 05:43 PM
A
Timer will have a hot wire coming in & a hot coming out. Using a volt meter see it you have current on the in side if you don't you have an electrical problem. If you do then set your timer to the on position & check for current coming out. If don't have current coming out your timer is bad. if you do than you have an electrical problem
Old 09-04-13, 06:01 PM
Received 1 Upvote on 1 Post
I just can not imagine a septic pump that runs off a timer.
How would it know when it was full?
Any I've seen used a float.
Old 09-05-13, 03:09 AM
A
It's called time dose. It's one of the solutions for problem sites.
Old 09-05-13, 02:38 PM
T
Is there a way to upload pics larger than 50K to this site?
Old 09-05-13, 02:43 PM
T
It's made by American
http://www.americanonsite.com/americ...List_Rev_A.pdf
Model number: SEQAB124-ACEJ1LX(PW)
I'm trying to get the pictures of it down below 50K so I can post them.
Old 09-05-13, 02:51 PM
T
Timer Pic
This is a picture of the timer
Old 09-05-13, 03:19 PM
T
This is the Timer from the manufacturer.
H3CR-F Solid-state Timer/Lineup | OMRON Industrial Automation
It's the H3CR-F8 100-240AC model.
I only see 9.5V on two wires going into it, one of which is looped from a single input from the bus panel. I don't see any lights on the Off indicator. Should I be seeing 120V on the input?
Old 09-05-13, 11:37 PM
If you read the description in the link you posted it says timer controlled by float(s). You probably have a bad float switch.
Do you have a schematic for the system ?
Old 09-06-13, 06:43 AM
A
The next thing you to do is open the access cover for the pump chamber.
You will have 3-4 floats.
lowest float (closest to the bottom) - off float
2nd lowest - enable float
3rd lowest (if you have 4 floats) - peak enable float
highest - alarm float
Before you do anything with the floats measure the distance from the bottom of the tank to where the float is attached to the float tree, because if you have to remove a float you need to put it back to the same height.
Now take a pole with a hook on it & raise the enable float. The pump should come on. If not it is probably a bad float.
