Fourth submersible pump burnt out in 3 years
Old 10-26-13, 08:48 PM
D
hi
I have a well about 80' deep. I moved into the place about ten years ago, 3 years ago my water shut off. The motor on the pump failed, the stamp said it was made in 1982. I had the pump rebuilt and installed it myself. It worked fine for six months and seized. I bought a brand new one with a new control box and that one jammed up. I thought maybe it was too low and maybe sucking up sand so when I exchanged it for a new one I installed it shallower. That one seized. Exchanged that one and last night it seized AGAIN! I must be doing something wrong. How can this be? I'm told a good pump can last 25 years. When I pull the pump out it has a lot of red slime on it. Could this be a problem? I am at a loss. Please help me. I'm thirsty and tired of going to the creek to fetch pales of water. thanks
Old 10-27-13, 06:23 AM
O
Received 8 Upvotes on 7 Posts
How old is your pressure tank and more importantly, do you know how much drawdown (amount of water between pump cycles) you are currently getting from the tank? Perhaps your pump is short cycling due to a ruptured pressure tank bladder? That can burn out a pump pretty quickly.
Old 10-27-13, 06:46 AM
Received 1 Upvote on 1 Post
The burnout
What about the power? Is the wire size big enough?
Sid
Old 10-27-13, 10:43 AM
D
The wire is about 12awg. I did read on this site about how to test the shrink connectors for leaks. I didn't do that, but im fairly confident its water tight. I set the pressure switch at 40 and the tank at 38. It holds pressure, could it still be shot? It is 30 years old. I do feel that the pump comes on too frequently even in the middle of the night. Maybe every 45 mins, is that normal? I didnt measure any actual drawdown.
Old 10-27-13, 11:32 AM
ray2047's Avatar
The wire is about 12 awg.
Wire size much meet or exceed the size required for the full load amps of the pump adjusted for distance from breaker box.
Old 10-27-13, 11:37 AM
Received 3,415 Upvotes on 3,063 Posts
Wire size based on length is an important factor but I think I'd run it by a local well guy.
See if there are any issues in the area that could be causing your problem.
Also....I'd find out what exactly is happening to the motor. Is the impeller seizing or is the motor internally seizing.
Old 10-27-13, 01:50 PM
The burnout
Is the pump oversized for the well?
Sid
Old 10-27-13, 02:03 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Could it be possible that the OP is only getting 120v on one leg to the pump? This would cause over heating from what I know, and eventually pump failure.......
Old 10-27-13, 02:40 PM
F
From the original post:
You need to determine what this slime is. Possibly biological or maybe just clay but if it is in the water it could be the problem with your pump crapping out.
lawrosa
Doubtful. A 240 volt motor supplied with only 120 volts probably would never start, especially a deep well pump that would always be seeing the head pressure from the discharge piping.
HOWEVER, low voltage as a result of using the #12 conductors may definitely be a factor.
Old 10-27-13, 02:49 PM
lawrosa's Avatar
Super Moderator
Yeah was not sure, but during hurricane sandy my not too smart neighbor hooked his 240v well with a 120v whip from his generator.. He had water but not a full stream. Apparently it started...
Just was not sure if say it was a split breaker with one tripped or a capacitor in the box may be going bad????
Old 10-27-13, 06:10 PM
Z
Received 91 Upvotes on 84 Posts
Diesel Rags -
...I do feel that the pump comes on too frequently even in the middle of the night. Maybe every 45 mins, is that normal? ...
Diesel and guys --- isn't that an indication of a leak?
Old 10-27-13, 07:15 PM
F
Yep, it sure is! Just WHERE that leak may be is anyone's guess. It could even be a leaking check valve allowing the system to drain back into the well.
I would still like to know what the red slime is all about.
Old 10-28-13, 06:44 AM
O
If I was replacing pumps every year or so I would want to check for two things in my set up, for sure.
The first is to look for a leak. Pretty simple. Let the pump cycle off and see if the pressure is maintained or if it drops. If it drops, over any time frame (give it an hour or so) you have a leak.
The second is to look for a damaged diaphragm in the pressure tank that will cause the pump to start short cycling. Measure your drawdown of water. That is the amount of water you get between when the pump cycles off and when it cycles back on again. If we are talking gallons, just use toilet flushes to get a ball park number. If we are talking quarts then use a 2 quart container and count them. Now do two things. Divide the drawdown into the size of your tank and if it is less then 10% you probably have a problem. Fully empty the tank (turn off pump and let the water empty out) and refill it and measure the drawdown again. If it significantly increases it is very likely your diaphragm is toast. You can monitor it over time and if the drawdown decreases over the next few weeks, your diaphragm is toast.
Those two problems can really shorten the life of a pump so I would at least check them.
