House pump turning on and off, losing pressure pretty instantly.
Old 11-18-13, 02:51 PM
So there's 2 pumps on this houses system. 1 for the Well, and 1 for the House. Both are outside, both are on tanks, right next to one another, basically. IDK if this a typical setup, or not. I'm new to these things, btw.
The well pump is operating fine. It's bringing water from the well into the bladder tank and then into a giant holding tank, I would presume. Then the house pump draws from the big tank, into a smaller diaphragm tank, and into the house.
The House pump is set to 30-50, or should be, but is seemingly set to around 30-32 to 52-55, something in that range.
When I heard the pump turning on and off, I went and unplugged it. I looked for leaks right there in the piping and couldn't see any. So I plugged it back in. It operated until about 55, shut off, and steadily dropped in pressure. I can't hear any air hissing, and it's on a Utilitech Diaphragm Tank. I checked the pressure in the tank with the pump unplugged, it was on 43 or 44, just about. That was with water in the tank, I would presume, as I don't know how or see anywhere to empty it from.
The pump is a Goulds J5S Single Nose Shallow Well Jet Pump, 1/2HP.
Old 11-18-13, 04:01 PM
P
Received 1,756 Upvotes on 1,569 Posts
It sounds like the check valve is leaking on the house pump.
