Crawlspace water problem.
After a long rain I have water entering through the CMU wall cracks. The water filters into the ground of the crawlspace in a day or two so I don't think I need a pump, I think it just needs to be diverted down into the ground if it does enter the crawlspace. I don't have a lot of money to hire this done and I don't think I can expose the footer for I have a bad back, I can dig a foot or so. I've attached 2 sketches of what I think I can do, COULD ONE OF THESE WORK, if so, what type of glue, caulk or mastic would be best to use to apply the rubber or I might use plastic, the block wall will be wet and dirty with Georgia clay.
Far better to address this on the outside.
Why not prevent it instead of dealing with it after it's already in and done the damage.
So many things can cause this.
No gutters.
Gutters with down spouts not far enough away from the foundation.
Grade not running away from the house.
Foundation not sealed.
No French drain.
Mulch piled up against the foundation.
Flower beds forming ponds.
No gutters.
No French drain.
I've addressed what I can from the outside without digging up my landscaping to water proof the wall or adding a drain. I would prefer working under the crawl space since I have a tenant in the house and a lot of bushes at the foundation.
Thanks,
Thanks,
While I agree that most of the moisture problems I have ever seen can be handled with proper gutters and grading, and internal french drain would not be ineffective here either.
Received 87 Upvotes
DIWoW
Grading away from the home is impossible as it would require the soil level to be several feet up on the brick siding. There must be many people with the same kind of situation, including catfish. Wish it were that simple!
p.s. maybe these homes should have never been built on that location? Maybe that's the answer?
I have water in my crawl space after a long rain. What I think is the problem is I have clay under the few inches of topsoil that was added. I've tried the long drain pipes from the gutters and got no change with the water problem. I installed a sump pump to take care of it. Much less work than doing a drain around the entire foundation.
Since I can't address the problem from the outside at this time I have decided to dig down to the footer in the crawl space and put a rubber liner down the block wall and footer with Henry Asphalt Emulsion 107, I'll also fill any large cracks with Quikrete 20 lb. Hydraulic Water-Stop Cement. I'll let you know how it works after the next heavy rain.
Thanks,
Thanks,
I found the same problem in the front with the bottom bricks turn on there sides and alot of mole holes along the foundation (really soft decayed top soil). I dug out a portion of the soft dirt along the foundation and down to the 12" block and filled this with concrete the whole 20' lenght. Once the concrete was hard I put some clay on top the concrete and sloped it towards the bushes 2' away. The bushes are not allowing me to slope any further than 2' and with the loose mole holy soil I still have water coming though the blocks, not really sure what to do now.
like the waffleboard - good idea - use conc nails to hold extrusion in place - pm me on extrusion source - would like to buy some in atl - thanks in adv
