Aerator for Septic System in Area with High Water Table??
I live in an area just outside the City Limits of Greenfield,In in Hancock County. My 1000 gallon Tank and 500 foot Finger System was installed in 1974. I became owner of this home in July 2013. The systems seems to work well for my Wife and I most of the time except in very-very wet weather - such as rapid snow melt followed by 5 days of rain in December when the ground was frozen. Shortly after this "rain spell" 3 loads of washing (Low water usage Washer) caused gurgling in a toilet nearest the Septic Tank. I checked to be sure System Roof Vents were clear - they were. The System was FULL. The time period from July to December (prior to the rain) we used the system without incident. We are familiar with Septic systems - this being our forth home with a Septic System - but the first "old" system.
The local Health Dept. advised me that Hancock County has a very high water table and I should limit our water usage and wait for the natural "Drying Out" process to occur over time. We have cut way back on water usage and now can flush toilets sparingly - but they work. The previous owner had the system pumped two years ago by a local - reliable Septic System Company. This company recommends pumping every 2-3 year particularly in our area - ie: High Water Table. I will most likely have the Tank pumped when the weather warms up - and put in a Tank Access Riser.
Is an aerator system such as: Septicaerator.com at 2 cfm beneficial? Is such a device Approved? (I know this won't help the excessive ground/surface water problem)
Comments appreciated.
Have you checked the D box for obstruction?
Read this... even though you have laterals this may give you some knowledge....
http://www.doityourself.com/forum/we...lp-advice.html
Your outlet pipe could be clogged
System was put installed in 1974, so my guess is you have non-PVC pipe.
We replace a lot of old non-PVC pipe
The only tank I would aerate is a 3 chamber tank.
Like Lawrosa said aerating that tank would just send a lot of solids to the drain field.
One thing that would help for now is do only 1 load of wash a day.
The piping in the crawl space leading to the Septic is PVC as is all of the other house drain pipe material. I have not done any digging but I would guess the buried pipe is PVC also.
When the weather warms up here in Indiana I will be doing some digging and engineering a solution. I plan to put risers on the septic tank and distribution box. The Health Dept said I don't need a permit but that they require that the original lids stay in place for safety.
Question : How did install the Inspection Port to check Liquid level in the tank? A piece of PVC pipe - but thru the lid or top of the tank// Core drill the concrete or ?? I need to gather some data.
Thank you for a great Forum.
The liquid level in a septic tank will always be 90% full so I'm not sure I'd bother with an inspection tube. If you had a cesspool I would consider it but septic tanks are designed to normally be mostly full. Unless you're out there checking the tank level daily your first indication of a problem will probably be toilets backing up.
I would like to gather enough data over time to understand what is NORMAL for our system. We have been owners of this 1974 home for just 7 months. With data I can schedule "pumps outs" when needed.
I would like to know how you or others have installed an Inspection port. Since I have to keep the concrete lid in place (local Health dept rules) the riser won't make inspection much easier.
