Water in pressure tank
Old 02-28-14, 06:30 AM
O
My pump was running 10 to 15 seconds on and 10 to 15 off while using water..... I tried checked the pressure and water came out the valve stem......Is the tank bad or is it something different..... Thank for listening
Old 02-28-14, 06:36 AM
Received 742 Upvotes on 648 Posts
Welcome to the forums!
Is it a bladder tank? if so, it's likely the bladder has ruptured.
Old 02-28-14, 07:00 AM
O
Yes it is a bladder tank.....So I guess that's not a easy fix......I'm guessing you have to buy a new tank.... The bladder can't be fixed......Thanks
Old 02-28-14, 07:07 AM
P
Received 1,772 Upvotes on 1,584 Posts
Correct. There is nothing you can do to repair a pressure tank. It's time to shop for a new one.
When you install the new one make sure your system has a working pressure gauge and you have a tire pressure gauge. The air inside the pressure tank, when the water system is totally depressurized, should be 2-3 psi less than the pump's cut in (turn on) pressure.
Old 02-28-14, 08:46 AM
O
Thanks time to go shopping......
Old 02-28-14, 09:18 AM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Actually you can just replace the bladder.
But the labor/hassle involved it may be best to buy a new tank.
Old 02-28-14, 10:25 AM
P
Try asking for a bladder at any home center. They'll probably point at your crotch and then the bathroom and tell you to hurry.
Old 02-28-14, 10:54 AM
lawrosa's Avatar
Super Moderator
LOL...
Well I have a craftsman... Ha ha..
$60 bucks but is it worth it?
http://www.searspartsdirect.com/part...dMod=&keyId=1A
Next one will be from tractor supply. Dont know the quality though..
$229 is not bad...
CountyLine® Pre-Charged Pressure Tank, 35 gal. Actual Capacity - Tractor Supply Co.
Old 02-28-14, 01:40 PM
O
Received 8 Upvotes on 7 Posts
Yes. Being 49 years old I sometimes think that I personally have one of those waterlogged bladders as well. lol. Not as easy to fix when it's the one you were born with.
You definitely have a burst bladder in your pressure tank. In the mean time, until you can get at it to fix it, you can always empty the pressure tank completely and then fill it back up again. This will stop your "on for 10 seconds, off for 10 seconds" short cycling. It can almost feel like it is fixed, but don't start "high fiving" anyone yet. The problem will return as the air, that you just trapped in the tank, starts to dissolve back into the water.
What it does do is reduce the punishment on your pump until you can replace the tank. Also, you should look at getting the largest pressure tank your space can accommodate. This will reduce the number of times the pump cycles on, increasing the useful life of that pump. Just my opinion.
Old 03-01-14, 06:09 AM
O
Thanks I give that a try.......
