Air in plumbing when well water pump is on
Hello,
I'm new on here, just purchased and moved into a house last week. Since I moved I noticed that our well water pressure was low. It's setup to 20/40 so I'm looking to eventually have it run to 30/50 if my pump will allow it. However, I have a more pressing issue, I have air in my water line. So the pump works fine, turns on when the pressure is just around 20 psi, which is where the fun starts. If there is water running at that time, air comes through the ,ex. kitchen, water spout. This fun time continues after the pump shuts off at 40 psi, until the pressure drop to about 30, at which point it stops. I read a lot of posts, but I'm not sure where to start looking. Is it a check valve, is it a seal, should I just not run the water when the pump is on? Please Help
Hello and welcome.....
I assume this is a shallow well and the pump is next to the well tank?
Sounds like you may have a small suction leak and its drawing in air...
First thing I would do is check the pressure in the well tank...
You need to shut off the power and drain the tank to do this..
With a 20/40 switch set the psi to about 15psi in the tank...
let us know ...........
Update to the original question
The pump is not next to the tank, so my assumption is that the water pump is one of those deep well sumbersible pumps. So then the leak can be anywhere from the pump line all the way to the tank correct?
I would not touch the pressure tank unless the pump is rapidly cycling with short run time. A pressure tank will never inject unwanted air into the plumbing system going on for days and days. (It may be responsible for some spurts of air for perhaps a day after you adjusted the air pressure in that tank.)
Very likely cause, the well is being overdrawn. A well may work without problems for most of the year but during a dry spell it might not be able to supply water at the rate that the pump is running at.
