Same problem(Sewage Pump Not Working)
Old 04-06-14, 08:04 PM
P
Hi
I realize this is an old thread,
http://www.doityourself.com/forum/we...t-working.html
but I have the same system and same problem.
Did you ever figure out the problem.
Sometimes my works, sometimes not. I know the pump works because I have a ball valve on the suction line before the filter. If I close the ball valve and fill the filter housing with water (which is how I prime the pump), then turn on the pump while adding water, the pump sucks it out as fast as I can add it.
Old 04-06-14, 08:12 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
Hello and welcome...
I will need to read that old thread to refresh my memory...
Dont have time tonight, but can you explain more on what exactly you have? And specific issue?
Thanks...
