Open well seal
Old 04-07-14, 10:40 AM
B
Open well seal
I suspect I have a bad foot valve in my pump. What's the best way to go about, opening and accessing the foot valve? What precaution do I need to take?
I tried turning the bolts are the well seal and they can jammed shut, I am trying to loosen them up with some wd-40, but not much luck so far.
Pics are here.
Size:  52.3 KBName:  CAM00325.jpg
Size:  50.9 KBName:  CAM00326.jpg
Size:  26.1 KBName:  CAM00327.jpg
Size:  32.9 KBName:  CAM00328.jpg
Size:  33.3 KBName:  CAM00329.jpg
Size:  53.2 KBName:  CAM00330.jpg
Size:  51.6 KBName:  CAM00331.jpg
Old 04-07-14, 10:46 AM
P
Received 522 Votes on 479 Posts
You pictures are not visible without logging into your account.
If your well cap looks similar to this one I'd just try a bigger wrench on the nuts. They will either break free or break off. You can also try using a chisel or block of wood to catch the bottom lip of the cap and pound upwards. It's just a friction fit and the weight of the pipe holding it in place.
Old 04-07-14, 10:58 AM
B
Thanks.
I reposted the pictures. The last one shows the two bolts. Do I need to do anything to support the pipes? What do I do, once (and if) I manage to open the well cap up?
