Irrigation pump to both a sink and irrigation system?
Is it possible to run water to both a sink and an irrigation system? How would I plumb it?
Right now, I just turn it off and on with the breaker. It would be nice to be able to turn on the sink and get water without dealing with the breaker.
If you are going to do that, you need a pressure tank and a pressure switch and you plumb it like you would a house.
It would be a lot cheaper and easier to run a pipe or hose to the sink from the house. That's what I did.
