Can this be used as a drain for emergency battery sump pump?
Old 07-16-14, 03:34 PM
1
I'm trying to cover all bases with my sump pump. I want to install a battery backup in case I lose power. Happened once this year and don't want it to happen again. The one I'm interested in is a WatchDog battery backup they sell at Lowes. The pump itself is pretty small but will fit right next to my primary pump.
Now my washer is only 10 ft. away. Is it possible to use the drain for my washer if I should lose power and the backup pump has to run? This way I would eliminate the 8ft height that the pump would have to use to pump the water outside. I would only have to connect the drain hose in the event of a storm. Thanks!
Old 07-16-14, 04:04 PM
V
Received 2 Upvotes on 2 Posts
As practical as that sounds, I'd approach it with caution. I'm a Real Estate Broker and once had occasion to sell a property where the Buyers elected to rig something up like that . . . . but while the lady of the house wasn't paying much attention, the sump pump was surcharging and elected to pump the excess dirty water upwards into one of her finished batches of clean laundry. She went into a tither.
Make sure your machine has a back flow preventer or foot valve of some sort to avoid that issue. I don't know about any other problems, and don't mean to suggest that there aren't any . . . . but this was a fun one to recollect. Of course they tried to blame me; but I never told them they should feel comfortable plumbing it the way they did.
Old 07-16-14, 05:05 PM
1
How I would do it in the event of a storm is I would take the washer drain hose out of the drain and put the pump hose in the drain. We have storms that will hit quick and I would not leave the pump hose in the drain at all times. I would just take it out and put it back where my sump pump is located.
The emergency pump has a regular garden hose fitting. I just thought since the pump is not having to push the water up several feet it would be that much easier on the pump.
Old 07-17-14, 04:14 PM
A
Received 250 Upvotes on 230 Posts
Do not pump into a septic tank. That will overload the septic system resulting in a backup.
Old 07-17-14, 08:52 PM
1
I don't have a septic tank. I'm on city water & sewer.
Old 07-17-14, 08:57 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
check you local codes... most towns don't let you pump into the sewer system....
Must be discharges outdoors...
As far as back up power, unless you have big battery bank they will not last a few hours...
Old 07-19-14, 11:10 AM
1
Do you think a portable generator is the way to go? I simply need to have a backup that I can depend on.
