Automatic low water pumped from ground level to house attic tank
Hi, I'm searching for a water pump with some sort of float to detect when water is low, so the pump will automatically fill the tank. The ground level tank is approx 10 meters from the house tank and a height of approx 10 meters. So I'm quite confused with all the different pumps etc...Any info or help on a type of pump that suits this would be very much appreciated, thanks in advance.
Dave Dreadbell
Dave Dreadbell
Welcome to the forums.
I've built the control circuits that turn the pump on and off using two floats.
You'll need to pick the pump you want to use and then the control system.
As far as I'm aware the pump and the control circuit is not available as a package.
Follow the link and see if this is what you need. Several ways to set up pump to control tank level.
https://www.plumbingsupply.com/index...ntrollers.html
