No water on well line.
Old 08-21-14, 06:41 PM
Hi, My water was running fine but I had a leak on the suction line. I emptied the water from the system and fix the problem.... Now, I connected everything back together and it looks like is no suctioning water from the well. I primed it and re-primed it but still the same problem. I put a vacuum on the well line itself but nothing comes out. Any help please? Thanks
Old 08-22-14, 08:22 AM
V
Vey
Vey is offline
When you prime, you have to fill the pump and all the pipe until you get to the first check valve. Then turn the pump on and leave it on until the water is pumped out and leave the pump on for another 15-30 seconds OR until you feel warmth from the pump body. Repeat as many times as you need. Sometimes it may take "many" times.
