pressure switch
Old 08-26-14, 06:52 PM
pressure switch
there are pressure switches for 120 volt pumps ,yes????are they cheaper than 240 ones??
Old 08-26-14, 07:53 PM
Tolyn Ironhand's Avatar
Received 59 Votes on 52 Posts
I don't know if I have ever seen one that is strictly 120 volt. You can use a 240 volt rated one and either wire it the same as a 240 circuit (breaking both the hot and neutral on the contacts) or just wire the hot to the contacts and splice the neutral through.
Old 08-26-14, 08:13 PM
Received 375 Votes on 352 Posts
You could buy a generic single pole pressure switch from amazon if price is your only requirement.
Well Water Pump Parts Single Pole Pressure Control Switch 0.8-1.6 bar - - Amazon
Old 08-28-14, 07:40 PM
pretty cheap
this is for working with the pressure tank,yes??
Old 08-28-14, 10:51 PM
Yes.... this pressure switch can work with a pressure tank. I'm not quite sure of the pressure settings. You need to contact the seller for the PSI rating.
